beemerphile1
Mar 26, 2014Explorer
kofire wrote:
I'll keep that in mind. There was nothing on in the trailer so essentially the power was off. Not sure if that makes a difference or not. That was not the problem this time. There were bare wires touching inside the plug, that was the problem.
Power supply, not the downstream items. There is good reason that code requires the breaker/disconnect to be near the receptacle.
However you are right, it wouldn't have changed the outcome in your situation. Just a tip that everyone should follow.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
