gitane59's avatar
gitane59
Explorer III
Apr 06, 2018
My first tire blow-out found me
Northbound on I75 just outside Tifton Ga we had a rear curbside trailer tire detonated with a load bang and lot's of rubber flying out behind our trailer. The H-rated Sumitomo 17.5 tires were just over 6 years old and had over 30K miles on them and I was planning on replacing them at the end of this season. Guess I waited just a little too long. It simply looked like the tread peeled off the tire carcass and the air escaped with a bang after that. I had validated air pressure at 105 PSI and visually inspected all tires just that morning. I think I trusted this type of tire just a bit too much.
A Georgia Champ roadside technician happened upon me about 15min later and assisted me to install the spare and I was able to get 4 comparable Falken RI-151 tires ordered and installed the next day in Tifton.
I was very fortunate to only have a damaged J-panel and a destroyed plastic tire fender out of the deal. My hydraulic levelling jack fluid lines were only 8 inches from the failed tire and my hydraulic brake flex line was about 10 inches from the exploding tire and neither received any damaged.
  • I had a blow out drivers side on i79 south of erie. No damage also but had to change it being one ft of the interstate. Took about an hour had to wait for traffic to past each time . Went and bought sailun also great so far its been a year with about 6000 miles on them. heading to Bristol next week so touch wood for another good trip with them.
  • Hey Oldbird1965, We have had great results with our Sailun's, on our second set the first lasting 6 yrs. I think you will be surprised on how much use you get from them. Good Luck and Happy Camping !!
  • I had 12 blow outs in nine years on my Travel Supreme even after switching to 17.5's H rated. Even put mor/ryde IS on, I don't know why. Bought Sailuns and will see how they do.
  • Hi..I have had two blow out. Both were a several years ago and neither one caused damage to the 5th wheel ... just lucky . .. jim2007
  • Glad the damage wasn't worse.
    I've had two blow outs. The first did no damage at all and the second only took out the plastic fender thingy.
    I consider myself pretty lucky.
