First off before you drop the underside enclosure really work the interior, open every cabinet, remove every drawer. You will notice hidden acess panels usually screws will be the first give away. Many of the fittings and connections that can leak can be accessed if you take your time and really get to inspect every inch of the interior. There are always some buried fittings that require a more aggressive approach but first rule out the easy stuff, good luck.....One more thing, water travels, the actual leak could be 10 feet away from the drip you see.
