JimK-NY's avatar
JimK-NY
Explorer II
Oct 08, 2022
Mysterious Propane "Leak"
Sorry about the length but I hope with enough details someone can explain what is a mystery to me.
After 5 years or so my propane pigtails had hardened. Since the regulator was the original from 2004, I decided I should replace it also. What motivated both was what seem to be very slow leak. I left one of my half empty propane tanks with the valve open but without using any propane for several months. When I finally checked the tank was empty. I put in a new tank, charged the propane lines, ran both the stove and the furnace. I shut off the tank and noticed the regulator showed red after a couple hours. I switched the regulator to the other tank, opened and then closed the valve and again the regulator showed red in a couple of hours.
After changing the regulator and pigtails. I did a careful leak test. No soap bubbles and absolutely no propane odor. This time, I used the stove and furnace and then shut the valves. I expected to see a green indicator on the regulator for many hours. Instead it changed to red in well under 2 hours. I switched over and had the same results with the other tank. I did several checks and the pattern repeated with about 1 1/2 hours until the regulator changed from green to red. I checked for odors and leaks everywhere with no problems.
It has now been several days since I replaced the regulator and pigtails. Last night I did another test and the regulator was still green after 4 hours when I went to bed. Today I did another check and it took 8 hours for the regulator to show red.
Any ideas that can explain this or point to additional testing?
