oldschoolhdmike
Aug 12, 2019Explorer
"leaking" fridge has caused trim to start rotting
so several months ago i noticed below my fridge there is a square access panel that had a bubble in it. i took it off and sure enough one corner was a little wet. there is not leaks under the fridge, so i found out the water is coming from the fridge during a defrost and it leaks right down through the door mount holes on onto the wood paneling. which is not wood. So i did what i thought might fix the issue and siliconed up the mount area and screw holes. then when it is defrosted i would leave towel at the bottom to soak up the water. well, about a month later it is worse and has spread to the panel to the side of the fridge. Even if i figure out how to fix the fridge from leaking down there, now i have a panel i have no idea how to replace and make it match. The access panel i can order and it is cheap but i do not want to replace it until i fix the leaking. My rv gets used quite a bit and even though i keep it plugged in sometimes i leave the fridge off/ open and clean it. so this is where the water is coming from, just melting/defrosting. any ideas? i have pictures but do not know how to attach them....
