wa8yxm
Aug 13, 2019Explorer III
\Dometic????
Two things on the Dometic fridge you need to know.
ONE there is a plastic tray under the fins. this is a DRIP tray. do not put anything on it. make sure the drip outlet lines up with the thing below it to catch the drip.
OUtside there is a tube may be black or white. generally ribbed. the end is plugged with a thingy This is supposed to exit via a vent hole in the cover so it DRIP DRIP DRIPs on the ground.
When mine was new it was still inside so it driped on a terminal board and what you see is what I got
WHen I had the recall done the technician said "I always put it out" he Lied.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
