alanaks
May 10, 2017Explorer
mystery propane leak
My propane is loaded on the tongue of my trailer. I don't use it all that often, so I close the valve when I'm not immediately using it. One day I opened the valve to use it for the first time in months and a very strong smell escaped the tank. I would perhaps put up with just a tiny bit of propane on the nostril in the past, but you would have to be right next to it. On this occasion, the leak filled the immediate vicinity relatively quickly. I went to investigate but saw nothing out of ordinary! All the connections seem tight, and if it were a nick in the hose (which I can't see/feel) the leak would be constant rather than only when I open the valve for use. Has anyone had a similar issue?
