CabinetmakerII
Oct 08, 2013Explorer
When it comes time to "winterize" (which is now), I drain all the tanks and open the low point drains. After all the water is drained I close the low point drains and I simply pull out my air comressor and "blow down" the entire system. I connect the air hose (regulated to 40 psi) to the city water connection utilizing an air chuck with a retainer to keep it on the valve stem. I then go through the RV opening each valve until I get nothing but air. I make the rounds three or four times to ensure I have all the water out. I also run the water pump for a minute or so to ensure no water remains in the pump. I then reopen the low point drains and leave them open till spring. I then pour some RV antifreeze down each drain to keep the "P Traps" from freezing. No issues with any seals or residual taste to the water.
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
