Veebyes
Feb 05, 2018Explorer II
Much also depends on what you consider good enough. If you need a pad length that will accommodate the full length of your trailer, stabilizers down, trailer as rigid as a house on foundations, then the choices are more restrictive.
If you don't mind the back hanging out over behind the pad, maybe not able to use the stabilisers & are content with a little jiggle when you walk, then your options are greater.
About Fifth Wheel Group
