Likes to tow wrote:
The Dexter chart I COPIED from the Internet said to torque first to 60lbs then do it all again to get them at 90 to 120lbs. That's a 30 lb variance and looks like to me this makes it not overly critical. Just get them tight. I'm doing 90 from here on. However I believe the most important part of torquing wheel lug nuts to to do it again after a few miles and then check it regularly like you would tire pressure. Like one poster mentioned, the heating and cooling of brake drums may make this more critical.
When I'm doing an engine overhaul I always go exactly as the manual says and that is a specific torque setting.......not a big variation. Rod bearings and cylinder head bolts have a specific recommendation. Apparently wheels do not.
Read page 73 & 74.
Dexter manualSteel, aluminum and aluminum with inserts all may be different, so go by the wheel manufacturers specifications.
