JKJavelin wrote:
You will get many opinions here, but I think the studs sheared from over tightening or, more probable, defective studs. You might want to replace all of the studs, and for sure, replace the other tire from that side. The remaining tire took the whole load from that side and may be compromised. I'm glad you avoided other damage.
JK
+1 on this.
Yes I have always used a torque wrench set to 105 and the oem studs would seem to stretch as the nut was tightened. It was like the steel was soft and as they were tightened it took more turn than expected before I would get a click.
Fast forward 10 years and I put disk brakes on my trailer. The lugs tighten much different and seem stronger where they snug right up and the wrench clicks firmly. Previously it would be an extra 1/4 turn where it should have been tight but had a soft finish.
I feel lucky to have never lost a wheel with the original AL-KO hardware.
