abc40kids's avatar
abc40kids
Need a little winter camping advice please
I’ve never camped past October and this week we will be camping for Thanksgiving. Temps will get down to 20 at night and at least one day only up to the low 30’s. I have a 2015 Montana Mountaineer 356TBF. I was told it had heated tanks and I have a heated city water hose. Any thoughts like leaving the water dripping.... This is all new to me camping below freezing. Thanks!
  • Check the propane every day. And check it at least an hour before the propane store closes.
  • I helps also to keep cabinet doors open where water lines are located.
    This allows heat from the interior to circulate around lines to help keep them from freezing.
    Barney
  • 2Rad4U's avatar
    2Rad4U
    Explorer III
    I would fill my freshwater tank and remove the city water hose from both the camper and the campground faucet.
    Keep the hot water heater on.
    In your situation, that's all I would do.
    I'm assuming you'll be in a campground.
  • “I was told it had heated tanks”
    Famous last words that can cost thousands in the RV world. Verify whether you do or not.
  • 2oldman wrote:
    Use your water tank, not a hose. And NO water dripping! Use your waste tanks and don't leave a sewer hose out with water in it. Use your furnace and keep the WH on. And don't be stingy with the propane.
    Agreed. A couple of small ceramic space heaters will help conserve propane, assuming shore power is available. A hair dryer might be handy for carefully thawing a known frozen pipe. Make sure your hot water heater is always working. A little venting, like a small opening of the bathroom hatch, will help, but not prevent, condensation.
    Lotsa propane...
  • Use your water tank, not a hose. And NO water dripping! Use your waste tanks and don't leave a sewer hose out with water in it. Use your furnace and keep the WH on. And don't be stingy with the propane.
