Peg_Leg
Aug 06, 2013Explorer
I'm on my second one. The first was in my 97 K2500, a 100 gal L-shaped tank. My present one, which I like better is a RDS 80 gal. The RDS has a roll over check valve in the top. I plumbed it into the filler neck vent line, this keeps both tanks at the same pressure.
Both tanks were gravity fed into the filler neck. Manual lever operated ball valves at the tank, 12v solenoid valves located under the bed with activation switch on the dash. Mine are gasoline.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 15, 2026
