grizz272
May 24, 2019Explorer
Need an opinion
My fifth wheel has a 15K btu AC. Do you think I can run the AC on low with 1 Honda 2200 inverter generator or will I have to buy 2 of the generators?
time2roll wrote:
You will need to understand where the power is going to give it a shot. Most everything else off or set to propane only. Still need 12v to run the controls so the converter should not be turned off but the battery needs to be charged. Also the higher the temperature the harder to start/run along with the generator will lose some power at higher elevation. Give it a go with one... worst case you buy the second.
[COLOR=]There is also a very highly rated soft start electronic control to replace the start capacitor that will really help if you need to stick with 1 generator.
The newest A/C units do better than the old so you have a pretty good shot at running on one gen.
