justme
Jan 13, 2016Explorer
Mostly an emotion decision. However, keep in mind that most mfg's put more effort into glitz and glitter over engineering. After one decides on floor plan and over-all looks, I think a close look at suspension, tires, wiring. plumbing, insulation, flooring, roof design, wall design and fit and build. Then what kind of fixtures, appliances and entertainment systems are installed. All mfg's cut corners and the big concern is where. If you are not knowledgeable about the technical aspects of a trailer, I would suggest getting a professional opinion because in the long run the cost will pay for itself. If you make the right decision in those areas you will have many years of happiness.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
