Sjm9911
Aug 08, 2022Explorer
Durb wrote:
Oak is an open grain hardwood. The first coat of an oil stain will pretty much determine the color. Additional coats will add some depth but not change the color much. A different colored stain may be required. Stains should always be tested in an obscured area. In my experience, trying to match a piece by staining is difficult.
When the manufacturer finished the wood, they sealed it. Surface sanding may give the appearance of bare wood, but it still might be sealed and not accept stain as readily. You might try treating it with a liquid paint remover. Then sand, and try again as mentioned in your other forum.
Ill agree, I always use clearwood before staining. I think it helps to open up the wood grain to accept stain or paint.
About Fifth Wheel Group
