obie311
Aug 12, 2022Explorer II
Thanks for the suggestions all.
Is Cleanwood a sanding sealer or just a cleaner like we used to use Prep-Sol when painting cars to get all the wax, grease, and handprints off the metal before painting?
Covered Wagon bear with me here as I want to take advantage of your knowledge, but I don't understand what you mean by "toning" the finish coat. Does that mean I would add some Miniwax 235 to a polyurethane satin top coat?
I'm missing a step here that the original furniture manufacturer did to make the finish more uniform. Is it possible that they used a toned sanding sealer first?
Luthiers use a sanding sealer on guitars, but maybe not for translucent finishes, maybe only paint. I found this warning on the internet:
Do not apply stain to the top of the sanding sealer. To work properly, wood stain needs to soak into the pores of the wood. Sanding sealer negates this process. The stain will sit on the surface and not be absorbed.
About Fifth Wheel Group
