covered_wagon
Aug 13, 2022Explorer
What happens in our industry is the wood will not go dark enough for various reasons such as heavy dense woods like oak, sometimes it's the summer growth with harder grain, all will only accept so much stain so adding more stain to achieve the look we may want isn't going to happen. Sometimes it's the summer growth rings ending up showing too light as compared to the spring growth causing radical light and dark spots in the surface.
The solution is to find a top coat finish, most often lacquer, that will mix with a lacguer thinner base stain and slowly mix the two till you achieve a slight tone or tint that is effective in darkening the surface. Sort of like laying tinted glass as a top coat but, with the right color or tone we want. You want to add only a little at a time to the liquid finish and test what it does till you achieve the look your going to want but, don't go too dark right off the bat because with a toned top coat you can always go darker by adding a second or third coat. Each time you coat will tell you if you want to add another to gradually tone it darker.
Lacquer is nice because pro paint shops can help with the tone you want. Also 00 fine steel wool does wonders to a lacquered surface.
About Fifth Wheel Group
