obie311's avatar
obie311
Explorer II
Aug 06, 2022
Need help from experienced woodworker
I have a little side table that came with my Arctic Fox RV. It had a deep scratch in it and I also wanted to use it as a test case for eventually refinishing the dining room table.
I started sanding with 100, then 150, then 220, and finally 320 with a palm sander. The scratch was gone as well as the original stain and the surface felt very smooth. It actually looked like it was constructed of Oak boards with varying tones. Some light and some reddish.
I read up on the Minwax system and it recommended oil Pre-Stain for soft woods and also was said to help the stain look more uniform. I applied as directed.
Right now I'm at two coats of 235 Cherry (as mentioned on the Northwoods RV forum) to be a close match to the original stain.
I was disappointed in the darkness of the two coats of stain so I did more googling and found that I had made a mistake in sanding the wood so smooth. Apparently the rougher the wood surface the darker the stain will appear.
I'm in a quandary as how to proceed from here. Should I try two or three more coats of the 235 stain and see how it looks? Would a gel stain have more pigment and give me a darker result? Should I "unsand" the surface back to 150 or 220?
  • You state you think the wood is OAK (a hard wood) so why did you use a stain for Soft Wood?
  • ^^Agree……..
    Also, the longer you wait before removing the excess oil, the darker it will be. I usually wait no longer than about 15 minutes before rubbing it off. I like to sneak up on the tone. Might take an extra coat, but better chance to get it close.
  • Be sure to use an oil based finish, I really like Helmsman Spar Urethane Clear Satin. It will give you a more rich color. Water based looks like you PIZZED on it.
    Hit it with 120 then 220 and re try the stain.
