kkirt1's avatar
kkirt1
Need help identifying trim piece - Pictures Inside
I messed up some trim on my Keystone Raptor and I am having difficulty locating a replacement. Both of the shops I spoke to say it has to be ordered from the OEM but every 5th wheel I have seen lately has this same piece of trim.
This trim covers the connection between the fiberglass front cap and the siding. It has a bendable aluminum track with a black "cap" that snaps over it. Seems pretty universal. Anyone know what the brand / name of this stuff is and where I can order it from?
  • Thanks. I was able to straighten the base and ordered the replacement cover.
  • Barney, take a closer look at the OP's pic above - his molding has a little extra tail to take up the surface thickness difference.
    S
  • Here you go! :)
    You might also try Bontragers RV Supply. They are located in SW lower Michigan quite close to Elkhart, IN where most RV's are manufactured. They have just about the largest supply of RV "stuff" that I have ever seen in one place. A great place to visit and roam around for half a day.:)
    Barney
  • That is called vinyl screw cover...Babette's RV and Marine Supply has a presence on e-bay...do a google search and the e-bay link will come up...They sell it by the foot and I bought enough to redo the white vinyl on my Keystone Outback that was mildewed...they also have other colors including black.
  • If you take a section off, there could be markings on the track or cover identifying product.
