code3run
Oct 10, 2013Explorer
So just soak the fiber plates? The clutch basket seems fine with no grooves. It does have a bit of play to it meaning I can turn it back and fourth about 1/2 inch or so, is that normal?
So when the new clutch kit comes I will soak the fiber plates, renistall it all back together. How tight do I tighten the screws? Is that it pretty much?
My main issue was holding in the clutch the bike would still be in gear and want to lurch foward causing it to stall everytime I came to a stop in gear. Hoping this might fix that.
Thanks
Thanks
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
