BigDogF250
Oct 11, 2013Explorer
I've got to ask, do you know how to adjust the clutch lever/cable and did you start there? Failure to engage is a clutch / plate problem. Failure to disengage is usually a cable/adjustment problem (cables stretch over time and need adjustment) unless there is damage to the basket preventing the movement of the plates or debris in the pack.
Download or buy a service manual, most of the items are pretty easy to work on. If you don't have a torque wrench buy one, almost every bolt on a bike needs to be tightened to spec, usually to make sure you don't over do it and rip out the threads.
Good Luck!
Good Luck!
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
