BigDogF250
Oct 11, 2013Explorer
I've always wanted a chance to use this one...
Adjust Clutch
In all seriousness, it's pretty simple. There is an adjustment at the lever that looks like a wheel. Pull back any rubber so you can see the cable and turn the wheel so that the end of the plastic cable liner moves AWAY from the handle. This will tighten or increase the pull of the cable from one end to the other. If you find the clutch slipping when you hit the gas with the lever all the way out you went too far.
Adjust Clutch
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
