centerline
Feb 20, 2018Explorer
who installed the 5th wheel hitch/plate in the truck?... if it was installed in the right spot, there is no way the truck could "wheelie"....
do you have a short bed pickup or a long bed?....
if the hitch is installed in the correct spot, it will be 1 to 2.5 inches ahead of the rear axle... the further the hitch is outside of these specs, the towing problem will increase exponentially.... too far the the rear and you will have a wheelie problem..
as opposed to a "BUMPER PULL" trailer, the truck should be able to tow a slightly oversized "5TH WHEEL" trailer without problems as long as the hitch is set up correctly... UNLESS its highly mismatched, in which case you would have other problems as well...
About Fifth Wheel Group
