Galena
Dec 18, 2014Explorer
Truck Dually Wheels
After looking at one ton trucks with dually wheels, I prefer the one ton trucks with single rear wheels. What would I be giving up not getting the dually wheels?
Cummins12V98 wrote:
Me thinks if dat Dually had da B&W hitch nun uf dis wood uh happnd.
The Mad Norsky wrote:
I posted recently in another thread, on about this same subject.
There is a really simple answer to this DRW v SRW fiasco that usually goes on way past its prime.
Do the math.
In other words, look at your tires capacity (weight wise) then figure what the heaviest loaded pin weight will be of any fifth wheel you are thinking of purchasing.
These figures are advertised by almost all manufacturers, and can be easily figured with just a few moments of anyone's time.
Doing the math has all the advantages.
Math does not go on for ten pages without an answer. It happens immediately.
Math does not tell fabrications.
Math does not tell war stories.
Math does not offer an opinion.
Math does NOT pit one poster against another. It is neutral, and, as I said, immediately correct with an answer, which is what any of us needs.
Math does NOT give you a personal impression of what one vehicle drives like or the other.
Math just simply gives you an answer. Impartial and quickly.
Now for those that say "what is this guy talking about???" here's a quick example of how the math answers.
New fifth wheel, 12,500 pounds unloaded with an advertised pin weight of 2,300 pounds. It also advertises a Gross weight rating of 16,500 pounds.
Just be reading the sidewall of your tires one can immediately know if they can handle this fifth wheel.
An answer. Not ten pages of back and forth.
The example fifth wheel above has a hitch weight percentage of 18.4 percent. (2300 divided by 12,500)
So the heaviest pin weight this model can generate is 3,036 pounds. (16,500 times 18.4 percent).
Now, what is the load rating of your tires??? You have an answer.
Not an opinion, impression, war story or otherwise. An honest answer.
One catch though. Folks with SRW (single) rear wheel vehicles MUST realize that those two tires in back are carrying the truck itself, so most likely you will use up a lot of that tire capacity for one tire in just the truck itself.
So when you look at pin weight, just think of it as all being on the one tire remaining and you will do just fine.
[img]
[/img]Veebyes wrote:
I see The Mad Norsky has not forgotten.
for the benefit of transamz9 & others who think that beefing up a SRW with airbags & such compensates for real extra width & stability when faced with a real emergency that cannot be ovecome with pulling power or braking power either, here it is.
Hurricane force sustained gust of wind hitting a heavy 5er broadside. The 5er had something like 80gal water in the low mounted tank & also a heavily loaded 12 cuft fridge on the windward side.
This is why I get rather passionate whenever the SRW vs DRW subject comes up. I will never forget the sound of the kingpin tearing out of the 5th wheel.
That was no 'barely meets specs for the trailer' hitch. It was a 20,000# hitch.
The truck stayed up on the highway. It mowed down a couple of those snow posts but it did not go down with the trailer.
The Mad Norsky wrote:x96mnn wrote:
@madI did not read your entire post, Are you trying to say it does not matter about the truck only the tires and what they can hold? If you are I do not need to hear anymore.
Tires are the major part. Tires and rear axle capacity are the weak points in fifth wheel hauling.
If one does the math then you will know if a SRW or a dually is needed to carry the pin weight of any fifth wheel.
Now 2500/3500, 350/250 has just been debated ad nauseam here on the forum over the years. Same-different-same-different and so on for page after page.
I figure if you're not overloading the tires, the truck is probably fine.
