Galena
Dec 18, 2014Explorer
Truck Dually Wheels
After looking at one ton trucks with dually wheels, I prefer the one ton trucks with single rear wheels. What would I be giving up not getting the dually wheels?
The Mad Norsky wrote:x96mnn wrote:
@madI did not read your entire post, Are you trying to say it does not matter about the truck only the tires and what they can hold? If you are I do not need to hear anymore.
Tires are the major part. Tires and rear axle capacity are the weak points in fifth wheel hauling.
If one does the math then you will know if a SRW or a dually is needed to carry the pin weight of any fifth wheel.
Now 2500/3500, 350/250 has just been debated ad nauseam here on the forum over the years. Same-different-same-different and so on for page after page.
I figure if you're not overloading the tires, the truck is probably fine.
