MFL
Feb 20, 2018Nomad II
With that short of bed, you likely have the pin center behind the axle. With the lightly suspended truck it makes matters even worse. You may need to get a sidewinder type pin box, and move the hitch forward, to have the pin at axle center, to slightly forward.
You need to have a friend, with some FW knowledge look over your set up. It sounds dangerous as is.
Jerry
Jerry
About Fifth Wheel Group
