jkwilson
Feb 20, 2018Explorer III
cswinford wrote:fnswhitfield wrote:
Check on the TV rear tire sidewalls for the maximum tire cold air pressure. Inflate to that number before towing.
Should you inflate to that number when the weather is hot? Just curious how you adjust as the air temp increases.
Inflate to the number on the sidewall no matter what the outdoor temp is. The sidewall will say something like "inflate to 85psi max when cold" which means when the tire is at ambient temperature.
About Fifth Wheel Group
