Dayle1
Feb 20, 2018Explorer II
theoldwizard1 wrote:
Very simple, the hitch was installed too far back. Period. END OF DISCUSSION ! Why it was installed there is a different question.
Changing springs (adding air springs) will NOT help.
Really not enough info to know for sure, but I would disagree 100%. Having the pin weight 4-6 inches behind the axle (if it really is) will only unload the truck's front axle by 100 lbs or so, but that is static weight. However, dynamic unloading can be more significant and part of the solution for reducing that effect is better damping of the truck's rear suspension. The truck likely has too much pin weight for the soft suspension and 'P' series tires. It certainly isn't doing 'wheelies' but it feels that way due to excessive suspension travel at the rear axle. And this can occur even if the pin weight is placed correctly.
Then there is also the impact of leverage on the truck since the fiver mass is acting thru the pin height which is about 30" higher than the axle centerline. That 30" lever is roughly 20% of the truck's wheelbase. Bumps and pot holes will have the fiver pushing and pulling on the truck. And with a light weight engine, front suspension will also experience a lot of travel.
Again too little info, so I'm just guessing, but an 8000+ lb dry trailer and maybe 9500 lbs loaded is going to have a big influence on a 1/2 truck that weighs probably less than 5000 lbs with soft suspension and 'P' series tires.
About Fifth Wheel Group
