Indianrock
Jul 12, 2014Explorer
Need more stability
We're in a Dutchmen 30 ft Fifth Wheel for several more months while our house is being built. I've done what I can with the stabilizers at the two rear corners and added jacks under the main slideout, but there is still a bit more movement when we move around than I'd like.
I've considered the king pin tripod stabilizers but might test with a 4x4 wood post first to see if it really helps. The four tires are probably not at specification on tire pressure by this time, but don't look especially low.
Hard to know if more or less tire pressure actually affects stability, but then there is the effect on the tire of being under load but at lower pressure ( this RV doesn't move much, will be in this park, then our our lot for a few months, then sold ).
