Bob6907
Aug 13, 2013Explorer
Need New Tires
Because I had a blow out on my one year old Towmaster ST 235/80/16 rated E made in China tires. I'm thinging of buying 4 new ST tires or LT tires made in the USA any ideas out there for size and make ...
FastEagle wrote:BeerCan wrote:
FE
I have pointed this out before. The placard is relevant info for the tires provided at the sale of the trailer by the manufacturer or its agent. It is not binding to the end user and does not prevent one from changing tires or wheels. As long as those items changed are sufficient to meet applicable regulation the end user is fine.
When you get done convincing the tire industry (T&RA) you're correct on that point let us know their official position.
Thank You,
FastEagle
S4.2.2.1 Except as provided in S4.2.2.2, the sum of the maximum load ratings of the tires fitted to an axle shall not be less than the GAWR of the axle system as specified on the vehicle's certification label required by 49 CFR part 567. If the certification label shows more than one GAWR for the axle system, the sum shall be not less than the GAWR corresponding to the size designation of the tires fitted to the axle.
