Dyno_Bill
Nov 01, 2013Explorer
larry barnhart wrote:
Ok I will ask again as I have done several times without a good answer. If Ed had 2 6 volt batteries and one went bad he would be in big trouble?? I feel he would but it seems nobody on this forum agreed the other times I asked this simple question.
chevman
As I'm sure you are aware most coaches use a 12 volt system. Your question is pertaining to a 6 volt system or a 12 volt system with the batteries hooked in series. There are 2 ways to connect batteries, parallel meaning that both positive posts are connected together and the ground terminals are connected to one another as well. With this method the system is a 12 volt with higher capacity . The other is series where the positive post on battery a is hooked to the negative post of battery b, the positive post of battery b is connected to the electrical system. This system will yield a 24 volt system. So that being said your question can only be answered after you share the method of battery connection and thus the operating voltage of the system.
About Fifth Wheel Group
