Me Again wrote:
mark5w wrote:
The drive tires of the TV are the only tires that need chains ore Blizzaks. The 5th wheel does not use chains or Blizzaks. ...
Out here when chains are required you have to chain up at least one trailer axle. Chris
It is generally recommended you do not mix winter tires with other types of tires on the same vehicle due to sometimes remarkable traction differences.
Also what Chris said about chaining up one trailer axle - we carry simple cable chains for this.
4 wheel drive etc will get you up the grade - it's coming down when the fun starts.
You want traction & control descending grades if you get caught out and conditions deteriorate.
If I were in your neighbourhood (sic :) ) we could go for a spin or two....
