rbcamping wrote:
Did anyone notice his axle weight? If you have two 7000 lb axles, you're already overweight. Did your weight include the bike?
Weight was with bike loaded. The dry weight of the trailer has 17% of its weight on the pin. When I hit the scales on the way home I had 12% of the trailers weight on the pin. I would have to add 800 lbs to the pin to get back to that healthy 17% ratio.... a water bed might do that. Even 200 lbs might make a huge difference. Adding a third axle to the trailer would be the ultimate fix and I might end up doing that yet.
