momentum_rv
May 07, 2015Explorer
Now I'm really confused. I was led to believe the drum brakes from LCI on my GD Momentum were "automatic adjust."
In looking at the "LCI Towable RV Master Manual rev 100313" it clearly states (on page 60) "Lippert Components, Inc. Electric Brakes are automatic adjust only." Then goes on to tell you how to adjust them manually if needed...?? Hmmm Then later says "NOTE: A second screwdriver will be needed to push the auto adjusting lever away from the adjuster wheel so that the starwheel can be rotated backwards."
I guess I'm going to have to pull a wheel/brake drum off and see if they are in fact auto adjust or not.
About Fifth Wheel Group
