TucsonJim
May 07, 2015Explorer II
momentum rv wrote:
Now I'm really confused. I was led to believe the drum brakes from LCI on my GD Momentum were "automatic adjust."
In looking at the "LCI Towable RV Master Manual rev 100313" it clearly states (on page 60) "Lippert Components, Inc. Electric Brakes are automatic adjust only." Then goes on to tell you how to adjust them manually if needed...?? Hmmm Then later says "NOTE: A second screwdriver will be needed to push the auto adjusting lever away from the adjuster wheel so that the starwheel can be rotated backwards."
I guess I'm going to have to pull a wheel/brake drum off and see if they are in fact auto adjust or not.
You can confirm this by calling Grand Design's customer service number at 574-825-9679. They are very well informed, and great folks to talk to. If possible, have your VIN number when you call them to expedite the call.
About Fifth Wheel Group
