CREATO
Apr 12, 2014Explorer
If your worried just buy the bearing cartridge press the old out and new in. Also low chance any auto parts store is going to stock them. That being said if you have the tag number off the axle you can call dexter and they will give you the part number for the bearing cartridge. Also if a 7k axel there are several different cartridges a 40mm and a 2 50mm one a 9/16 wheel stud and a 5/8 wheel stud. There is a process for checking the bearing end play with a dial indicator with rims off measure free play at hub. On a 50mm bearing I believe if within .008 you are good to go.
Reread your op you more than likely have 7k axels with 8k hubs this is something that was kinda specific to WRV On the Alpenlite 5vers.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
