Old-Biscuit wrote:
Cummins12V98 wrote:
Lantley wrote:
Cummins12V98 wrote:
Why do people think they need Timbrins/air bags or anything when the truck is loaded and sits level as the pic of the op's shows?
Trucks are supposed to "squat". Op drive your combo I bet everything will be fine!
It's ridiculous to see so many TV's with the ass end sitting high going down the road with the RV nose high because someone thinks they need to be sitting ass end high like when they are running solo. Also it makes for a very rough ride!
If you are within specs you don't need to add anything.
The OP's headlights are pointing to the sky. They need to do something!
Unless the OP wants to shine their lights in the eyes of passing motorist.
Sorry his truck is setting exactly as it should when fully loaded.
My 3500 RAM with 4,500# pin weight sits level also. My headlights don't shine towards the sky and the op's don't either.
The people that have their rear sitting low to the front should get a heavier duty truck. With that condition they are overloaded. Point is trucks that "need" a bandaid are overloaded.
I assume your truck squats when loaded with your RV. Do you feel the need to raise the rear to solo height? I have seen trucks exactly like yours and mine with airbags and they are going down the highway with the bags pumped up with the rear at solo height and that causes the front of the RV to be noise high and that causes too much weight to be on the rear axle and makes for a rough ride.
The OPs picture was taken shortly after getting trailer......it's NOT loaded up. (Go back and read OPS first post with pictures)
And OPs truck is squatting with an empty trailer.
I did re read
"We will weigh the rig next weekend after we finish loading it. I should have no issues being within specs as I crunched all the numbers from a worst case scenario for the 5er (gvwr w/ 25% pin weight) and used actual loaded scaled weights on the TV"
They were camping so they were partially loaded and he says he will still be within spec with even 25% pin weight. Unless you are full time 20% is probably more accurate.
Bottom line the truck in the pic was sitting fine! Even with more weight it won't change any noticeable amount when "fully loaded".
Op weigh your rig when fully loaded tow with it and if the truck sits like in the first pic DRIVE IT!
Now if you want to improve the ride bags can help. I run mine at 30spi and it does not change my ride height at all but it does help control the springs on some of these nasty roads.
They have a 3500 it is designed to ride LEVEL when loaded!
