ZeeLet50's avatar
ZeeLet50
new 5th wheel hitch info needed
Our purchase of a 5th wheel is not far off so I am doing my investigating of hitches. I would like the Andersen Ultimate hitch as its lightweight and easier for me to remove. I would also like to not have rails in the bed all the time. So solution is to use a B&W turnover ball under bed mount. Now this is where I am not sure but I will need a mounting plate to adapt to the ball and provide rails for the Andersen to mount. There is a Demco DM6140 mount that appears to do this job. My question is am I thinking properly here or is there something I am missing. Does anyone use a setup like this? Will this be a solid setup? 5th wheel GVW is 13.5 and its going on a '16 GMC 2500.
  • Wow, plenty of opinions here and thats what I am after. There is obviously many ways to approach this. Thank you all for the input.
  • john&bet wrote:
    rbcamping wrote:
    If you are going to have a goose-neck hitch, ball in the bed of the truck, and you are going to have a trailer that uses a Lippert frame, you might want to look at a Reese Goosebox so you won't need a hitch at all.( nothing in the bed) This is a little more expensive but no lifting, less weight, and it's an air ride system as well. I'm going this route.
    X-2. Mine is here waiting on the weather to break. Truck is due here in < 10 days. Oh and the ball is here to.
    Don't forget the chains.
  • slapshot12 wrote:
    jkwilson wrote:
    The Andersen Ultimate 2 mounts to the B&W with no need for any plate or rails. It pins the ball in place inside the Andersen and you tighten 3 bolts to lock it in place. Many people put a rubber mat under it to keep it from marking the bed liner.
    I love mine. You can really carry the entire hitch in one hand.
    That is what I'm using also, right down to the rubber mat. I'm very happy with the entire set up.
    I also use the Andersen Ultimate hitch and so far no complaints except it's kind of pain to have to climb up in the bed to hook up the safety chains.
  • This is the most innovative hitch and is worth consideration. :-)
    http://www.blueox.com/trailer-towing/super-ride/
    I saw that a few weeks ago. Very interesting.
  • WOW.. $1500 Looks like they only have a slider version looks cool but I think for me the cost would push it out seeing as I have a LB
