bp122084's avatar
bp122084
New Attitude Trailer Leaning
I picked up this 2018 Attitude 28IBG model few weeks back. We took it out last weekend, and I was surprised how unpleasant the towing was. I had a quite a bit of sway and felt the trailer was pulling to the sides the entire trip.
After I got home and unloaded the trailer I notice the trailer sits pretty unlevel side-to-side. The left side does have a slide and side kitchen, but I was surprised that you can actually see it leaning.
When I load it, I place my 1800 lb rzr on the right side of the trailer, so I would think it would even it out a bit; however, is this lean while the trailer is empty normal? Or should I be concerned something isn't right with it?
  • Had a shock break on my Sundance and it looked just like that. Also check tire wear as that would be a tail tail sign of broken spring shackle or shock.
  • I would so agree with something seriously wrong. I do also think it's a lot for that Tundra to haul. What's the tongue weight with the 1800 pound beast in the back? 3/4 ton or even 1 ton makes a huge difference.
  • A broken spring would not surprise me. In 2011, I broke a spring in south Texas (thought it was strange that I needed leveling boards when the campsite looked perfectly level) but pulled the fiver 1000 miles to home without realizing anything was wrong. Only after I got home did I notice that there was one broken spring.
  • Something definitely doesn't look right with the trailer but I think your tow vehicle is part of the towing problem. I loved my Tundra and I will stand up against any of the haters on here, but frankly that is way too much trailer for a stock Tundra. Even more so for one with a 6" lift and big tires.
    The dry weight of that tt, at nearly 8k, is about as much as a stock Tundra can handle comfortably. Forget about the fictionary tow rating. The dry tongue weight of 1060lbs exceeds the receiver rating before you even load it. Unfortunately, I see a new truck in your future.
    I towed our current trailer at 7600lbs loaded with our '07 crewmax. It pulled fine but we were overloaded even though nowhere near the tow rating. I wouldn't want to go any heavier. You are WAY heavier.
  • bp122084 wrote:
    GordonThree wrote:
    Was it leaning during your PDI / initial walk-through? From your picture, that would be pretty hard to miss.
    I didn't really pay attention during the pdi. We did the walk through pretty fast and it was also inside a large garage bay so I didn't really get to stand back and look at it. You can't really notice it unless you're looking directly at the front. Although pulling it home that first day, I felt that something wasn't right with how it towed. It's pretty heavy, but felt as if it wants to pull to the side more than anything I've towed before.
    i hear ya on that, lots of take in at a pdi.
    how about something simple like air pressure on all four tires?
  • Was it leaning during your PDI / initial walk-through? From your picture, that would be pretty hard to miss.
  • Start looking at the springs. Then get it weighed side to side.
