RoyB
Feb 18, 2018Explorer II
Sometimes I have removed my batteries and put on the work bench for winter storage and hooked for charging and see the batteries starting to boil out fluids. This has always been the result of overcharging in my case. If my maintainer charger is putting out 13.6VDC for a long period of time I will start to see the boiling out of the battery fluids... When my PD9260C smart mode charger on my OFF-ROAD Trailer does not see any DC current being pulled from the batteries it will switch down to 13.2VDC mode until something starts demanding DC Current again. Then it will switch to the 13.6VDC mode... The 13.2VDC mode seems to NOT cause the batteries to start boiling out their fluids in my setup.
My PD9260C on-board converter/charger pretty much takes care of my batteries automatically however out of habit I will still check the batteries for over heating and fluid levels etc on a scheduled basis...
My original OEM single mode battery charger only put out 13.6VDC and before I started checking the batteries in 2008 one of my four GP24 batteries boiled out all of its fluids and shorted out on me with-in a couple of months.
I usually leave my three remaining batteries sitting on my trailer tongue during the winter here being switched to OFF and just check them every couple of weeks or so. If the overall Battery charge state drops below 12.4 I will switch them back ON and allow my on-board converter/charger to take over again for a few days to bring them back up to a 100% charge state.
Most of the time I can have my main battery switch switched to OFF and the battery bank will not drop below 12.5VDC during the winter months just sitting there...
I still check them about every two weeks during the winter months...
When my battery bank is switched OFF I still have my roof raise controls and my Breakaway Switch along with my 12V Battery Monitor panel leads still directly wired to the MAIN battery cables. The 12VDC Power Distribution Panel gets switched out when the Battery Switch is switched to OFF.
My original batteries installed in late 2008 have performed great until the 2016 season and the three remaining 12VDC GP24 batteries in parallel just won't hold a standard charge for very long anymore. I am currently in the process of replacing my batteries for new ones now... Seems like everytime I get alittle ahead to replace my batteries I get another home emergency so my OFF-ROAD POPUP trailer gets put on hold again hehe...
Hopefully this upcoming season I will be back on the trails again here locally around Virginia... I have been doing alot using a single 12V Truck start Battery here running my POPUP trailer in my back yard setup location just to keep things going... I am really looking forward to getting back in the real camping mode again...
Roy Ken
Roy Ken
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 15, 2026
