Artum_Snowbird
Nov 20, 2017Explorer
Had exactly the same thing happen. Measure the voltage at the converter terminals themselves, then at the battery terminals. It should be the same, over 13 volts.
If it's not, then there is a loose main feed from the converter to the battery. In my case I had to tighten the screw holding the negative wire right on the negative terminal strip.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
