4bearhug
Mar 27, 2018Explorer
I don't have a slider but I always lift mine out with the the front leg jacks of the 5th wheel. Nice and easy way to get it out and saves you a back breaking job. Mine will get stuck tight occasionally where it will start to pull up the bed of the truck instead of the hitch. Easiest fix for that is start the engine and put it in drive and/or reverse and just ease off the brake enough to allow truck to move slightly. That always does the trick in freeing up the bind. Hitch just lifts right out then and you can take it off king pin or leave it hang.
About Fifth Wheel Group
