I found out what's getting these LED drivers so hot. It's the dimmer switch... If I run the side floods at full output the drivers only get warm. I can still hold them in my hand but they are fairly warm. If I turn down the dimmer the drivers get EXTREMELY hot to the point it will burn your skin. I'm going to be replacing the dimmer switch on the side floods with an on/off switch like the rear floods are on. It was nice to be able to dim the side lights, but after seeing how hot these things get its not worth the fire risk IMO.
