- RustyJCExplorer
Cummins12V98 wrote:
RustyJC wrote:
When you're traveling, it doesn't matter. The RV batteries are being charged by the truck's alternator (assuming you have a Pollak-type 7-pin umbilical). Our residential fridge is powered by a 1500 watt pure sine wave inverter through a transfer switch when we're on the road.
Rusty
Our new MS on order has a 1,000watt inverter specd for the frig use only is that enough?
Two 6V batteries also.
DRV thinks the 1000 watt inverter is sufficient for the fridge only. RVs for Less installed the 1500 watt pure sine wave inverter and transfer switch on ours before we took delivery.
Rusty - Power outage maybe 2 to 24 hours. Longer if you have solar.
In transit should not be an issue. - JTracExplorer
Cummins12V98 wrote:
Rusty
That is exactly what we have and it has worked perfectly for 3 full seasons for us. We generally spend about 3 months a year in ours. We have averaged about 7K miles for each of those years. The inverter is a pure sine wave which I think is better for the refrigerator. We have a Samsung RF197 French door fridge with an ice maker. Also, we have an automatic transfer switch which automatically switches the fridge to the inverter when we unplug from shore power and vice versa. A nice feature if you can get it. - AJS211ExplorerYes perfect I got all the info I need to make up our minds going for the real frig thanks for all the feed back
- Cummins12V98Explorer III
Rusty
Two 6V batteries also. - pcm1959Explorer IIWe have 2 6 volt golf cart batteries and a 1000 watt inverter. In 90 degree heat, it takes about 3 hours to get the fridge to proper temp and we still have 2/3 battery power left. Once we plug in to the truck, the charge from the truck keeps the batteries from dropping any lower on a trip allowing plenty of power to run the disc brake pump, etc.
As others have said, if unopened, the fridge will stay cold enough for hours during travel.....just depends on how hot it is outside.
If you don't boondock, I see no issue with the residential.
I hated the Norcold in our 2014 Lifestyle that I pulled it out and replaced it with a residential Samsung only after 6 months. BEST upgrade I have ever done on any RV. Phillip - Eng208ExplorerI put a residential fridge in our unit about three years ago. I love it. It is so much better than the Nevercold that was in there. I don't worry about running it when traveling. We have traveled for up to 8 hours in a day without being plugged in and still had ice in it and the fridge was still plenty cold. We don't boondock though.
- JTracExplorerWe've traveled all day several times with our residential Samsung running off our 1000 watt psw inverter and 2 6 volt batteries. The batteries have always showed a full charge when we got to our destination. As Rusty says, the truck will help keep them up. I did some calculations some time back and based on our battery size and with the Samsung running full time we could get about 8 to 9 hours. Of course, the fridge will not run full time so the actual time would probably be far greater. We never boondock so it is not that big a deal to us. We do enjoy the bigger capacity and the consistent temps a residential fridge provides.
- RustyJCExplorerWhen you're traveling, it doesn't matter. The RV batteries are being charged by the truck's alternator (assuming you have a Pollak-type 7-pin umbilical). Our residential fridge is powered by a 1500 watt pure sine wave inverter through a transfer switch when we're on the road.
Rusty
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
