T-bones
Jul 08, 2013Explorer
New Fuzion with brake problems
So on the way to our last camping trip I noticed my gas mileage going out the widow, before I would avg 19-22L/100km(sorry that's what we do up here in Canada) and 3/4 of the way my mileage went up to 30L/100km and my P3 controller started telling me I had no brakes and there was an "input overload". Now this would come and go every 2-10 min and stay on for 20-60sec, it was enough to pull over and reconnect the factory controller in the dodge just in case it was the P3. It wasn't the case, the dash would blink and tell me to check trailer wiring and no brakes.
When I got to location I found one of the lines to the rear axle was out enough that it rubbed on the rim and was possibly grounding on the brake drum, so I taped it up and figured problem solved right? NO
On the return trip same issue and same excessive fuel consumption as well, mind u I did have a full load and 2 Harley's in the back. So I get home unloaded everything and took it to the stealership for the check up. They also found 1 marrett connection in a junction box which the plastic cover had come off. Problem solved right....NO
Picked it up tonight after they had closed got it about 20 miles and the "no brakes" flashed in and then back out, so I pulled a 180 and back to drop it off again and on the rest of the way I quickly lost the brakes twice.
As I pulled into their parking lot one of the salesmen was unloading a boat so we had a chat and it turns out he actually went for the ride along when they tested it out. He said in the Ford they were pulling it quickly said trailer disconnected and they thought nothing of it! I mean really?...
So now I wait till tomorrow and see what happens.
I'm wondering if anyone else has heard of the brakes shorting and dragging slightly, because after unloading it on the way to the dealer and even the back and forth it still seams to be pulling like the brakes might be dragging?
