Flashman
4 years agoExplorer II
New Sailuns.
I just mounted new Sailun 235/85/16s. Should I run 110 PSI or 95 PSI. I got both opinions at the tire store. I'm in Tucson and we get hot - does that make a difference?
joebedford wrote:Cummins12V98 wrote:joebedford wrote:
I have Sailun S637s. I run 110psi despite the fact that I have "only" 2600lbs on each of 6 tires.
Your tires, your money but that's one HE!! of a rough ride! Center tire wear and less stopping ability.
FWIW, the last set of tires wore out at the edge of the tread, not the middle. They were E rated tires inflated to 80psi
Not many can say this towing a 5er with 6k pin weight 1/2 of the trucks miles.
But heck maybe I should run MAX of 80psi on all six tires?????
I run 80 psi on my truck all the time but then I don't have a trailer with 6K pin weight (mine's only 3060)
JIMNLIN wrote:bucky wrote:Cummins12V98 wrote:
Weigh your tires separately if possible. Use the weight/inflation chart for your tire size and load range. Add 5psi to what your chart says. This is per GY Tech support. You will get some nay sayers on here but I have towed many thousands of miles using inflation charts on vehicles and RV with great results. Better stopping, ride and tread life.
This is exactly right. Heed the advice.
Advise from Goodyear officially comes from their websites "weighing RVs" which follows advice from tire experts like Tireman9 and a host of other website blogs on proper tire pressures for tire in a trailer position.... ;
Goodyear Tire and Rubber .... weighing RVs
Special Considerations
** Unless trying to resolve poor ride quality problems with an RV trailer, it is recommended that trailer tires be inflated to the pressure indicated on the sidewall of the tire. Trailer tires experience significant lateral (side-to-side) loads due to vehicle sway from uneven roads or passing vehicles. Using the inflation pressure engraved on the sidewall will provide optimum load carrying capacity and minimize heat build-up**.
Of course Goodyears and tire experts thinking is the trailers tire selections were per the FMVSS regs...not a rv rookie severally over tiring the trailer to the point of having to derate the tires sidewall pressures/best sidewall stiffness.
BarneyS wrote:
I am not towing now but for about 36 years I always inflated my trailer tires to the max indicated on the sidewall. I never once in all those years had a blowout or any other type of tire problem other than a couple of punctures.
Unlike car or truck tires, a RV is usually pretty close to the tire weight limit all the time. Add in all the twisting and dragging when turning and you have a very bad situation for the tire. Hence, my recommendation is to follow the guidelines of most of the manufacturers and fill to the max as indicated on the sidewall.
Barney
