I just mounted new Sailun 235/85/16s. Should I run 110 PSI or 95 PSI. I got both opinions at the tire store. I'm in Tucson and we get hot - does that make a difference?
Weigh your tires separately if possible. Use the weight/inflation chart for your tire size and load range. Add 5psi to what your chart says. This is per GY Tech support. You will get some nay sayers on here but I have towed many thousands of miles using inflation charts on vehicles and RV with great results. Better stopping, ride and tread life.
