The shocks on my Newmar 5er has about 25k miles. Any comments about replacing the shocks. How do we know if they need replaced and if so, which brand have you used? Thanks for the reply.
Best way to test them is to unbolt one side and compress it by hand. If it flows easily in and does not return out it is shot and needs replacement. If it is bad make sure they are all the same size, should be, pull one off and take it down to napa. They will match it with one and send you home to change them out. I would be surprised if they are bad after 25k.
