flipper2222 wrote:
GVWR 8645 lbs, GAWR 4000 LBS Front and Rear, Dry weight 6669. The instructions said 50 Lb PSI. The Twerking was on a 4 lane highway and empty.Straight from the tire store. I thought the wheel were going to come off the payment. He was going the speed limit.
Twerking is something a camper or a 63 yr old should not try. It is not good for either one.
you will not get the proper info with out telling us the tire size...but if the label on trailer says 50 psi and they replaced with the same size tire on the label ...more than likely you should run 50 psi...need tire info.
